Specifies the time interval in seconds within which RIPng sends update packets.
| seconds | Specifies a time in seconds. The range is 10 to 3600. |
30 seconds.
The router exchanges an update message with each neighbor every 30 seconds (default value), or if there is a change to the overall routed topology (also called triggered updates). The timer granularity is 10 seconds. Timer minimum is 10 second and maximum is 3600 seconds.
configure ripng updatetime 60
This command is available on platforms with an Edge, Advanced Edge, or Core license. For licensing information, see the Switch Engine v33.1.1 Licensing Guide document.
